Displays nexthop ipaddresses, up/down status, health-checking (ping/ARP/ND) and ACL bindings.
| flow_redirect_name | Specifies the name of the flow redirection policy. |
N/A.
None.
The following example displays information for all redirection policies:
Switch.1 # show flow-redirect Name Nexthop Active VR Name Inactive Health Count IP Address Nexthops Check =================================================================== pkh 2 2001:400::100 VR-Default Forward PING ND: Neighbor Discovery
The next example displays an IPv6 redirection policy for a longer IPv6 address, which causes a two-line display for the related redirection policy:
Switch.13 # sh flow-redirect Name Nexthop Active VR Name Inactive Health Count IP address Nexthops Check ==================================================================== pbr1 2 2004:1000:1000:1000::10 VR-Default Forward PING ND: Neighbor Discovery
This example displays information for a specified IPv6 redirection policy:
* Switch.14 # show flow-redirect "pbr1" Name : pbr1 VR Name : VR-Default Inactive Nexthops: Forward Health Check : PING Nexthop Count : 2 Active IP Address : 2004:1000:1000:1000::10 Index State Priority IP Address Status Interval Miss Success ============================================================================== 0 Disabled 200 2003::10 DOWN 2 2 5 1 Enabled 100 2004:1000:1000:1000::10 UP 2 2
Support for IPv6 flow-redirection policies was added in ExtremeXOS 12.7.
Ping success count information added in ExtremeXOS 22.7.
This command is available for IPv4 and IPv6 flow-redirection policies on the platforms listed for the Policy Based Routing feature in the Switch Engine v33.1.1 Licensing Guide document..
